| Version(s): | All | ||
| Area: | Warning | ||
Problem:
The following appears
Intel(r) Visual Fortran run-time error
forrtl: info (58): format syntax error at or near .2) ûÿÿÿ
OK
Pressing OK button and then the following appears, and then the application crashes.
forrtl: severe (62): syntax error in format, unit -5, file Internal Formatted Write or ENCODE
Image PC Routine Line Source
libifcoremd.dll 77AD19D2 Unknown Unknown Unknown
libifcoremd.dll 77B317F7 Unknown Unknown Unknown
autopipe.exe 01051AB9 Unknown Unknown Unknown
autopipe.exe 0092CC34 Unknown Unknown Unknown
autopipe.exe 0060D1E1 Unknown Unknown Unknown
autopipe.exe 009654FE Unknown Unknown Unknown
autopipe.exe 00647FC8 Unknown Unknown Unknown
autopipe.exe 01092544 Unknown Unknown Unknown
autopipe.exe 01089B9E Unknown Unknown Unknown
autopipe.exe 0101A904 Unknown Unknown Unknown
autopipe.exe 012ED771 Unknown Unknown Unknown
autopipe.exe 012F8AE6 Unknown Unknown Unknown
mfc140.dll 13A1507E Unknown Unknown Unknown
autopipe.exe 01312091 Unknown Unknown Unknown
KERNEL32.DLL 75F18674 Unknown Unknown Unknown
ntdll.dll 77785E17 Unknown Unknown Unknown
ntdll.dll 77785DE7 Unknown Unknown Unknown
OK
Why and how to avoid it?
This issue has only been report to occur on one computer running AutoPIPE. the solution was to set Results Model options "Minimum Stress Ratio" = 0.00.
Visual Fortran run-time error messages
