| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT; | ||
| Area: | Stress Isometric | ||
| Date Logged & Current Version | Feb. 2016 10.00.00.10 |
How to modify data table color & font on an AutoPIPE Stress Isometric using OPIM?
This feature is related to border file. In order to modify drawing area you have to perform following steps.
1. In AutoPIPE launch Openplant Isometric Manager from menu “File > Launch Openplant Isometric Manager”
2. Open any border file you want to modify from “[Installation Directory]\isoextractor\Borders\...” i.e. I have selected DGN\A0BORD.DGN
3. Make sure you open a border which has table section already defined
4. Press “Settings>View Attributes”
5. On View Attributes dialog select “Text Node” and close the dialog. You can see in the snapshot below
6. You can see text node # 80 defined for data table
7. Go to the Element>Text Styles and activate “Report Style”
8. Change font and color from there and press save on “Text Styles” dialog
9. It is not recommended to change font of text in a table because if the size increase the text probably goes out of the table section
10. Close OpenPlant Isometrics Manager
11. Make sure to use the same border during export to Stress Isometric using AutoPIPE.
