| Product(s): | AutoPIPE |
| Version(s): | 2004, XM, V8i, CONNECT; |
| Area: | Stress Isometric |
| Date Logged & Current Version | Aug. 2016 10.01.00.09 |
How to physically move the Stress isometric dimensions and node names using OPIM?
See Video below:
Note:
1. This feature will only work with *.DGN files and not DWG files.. Save the file from AutoPIPE as a *.DGN, make your modifications in OPIM using this tool, and then save the file as a *.DWG from OPIM.
2. Some user may need to expand the video. To do this right click on the video and select "Copy Video address", paste this copied link into a URL address bar to download the video. Save it to your desktop, double click the file to start watching the video.
Customize AutoPIPE Stress Isometric drawings
