Users can log onto the LEARNserver and walk through training material at their own pace. There will be a practice workbook that the user can download. For some, there will be videos available to watch that will go through the examples in the practice workbook. These videos will be broken down into 15 minute or less section, focusing on specific topics. The goal is to have videos available for all classes, which is what we are working on. There will also be an assessment available for the user to make sure the training content was understood.
| Effective Interoperability between Design and Stress Engineers |
| Perform fatigue analysis for cyclically loaded static equipment |
| Understanding Piping Loads on Rotating Equipment Including Vibration |
| Optimizing Pipe Stress Design – Unparalleled input, analysis, and post-processing options |
| Consider motion, seismic, and wind loading with ease for optimized pressure vessel supports design |
| Performing Occasional Load Analysis |
| Performing Seismic and Wind Analysis |
| Key Updates Included in the CONNECT Edition |
| The Latest ASME and EN 13480 Code Updates explained |
| Offshore and Subsea Pipelines |
| Faster More Productive Modeling |
| AutoPIPE Isometrics Manager New Features and Benefits |
| The Benefits of Using AutoPIPE for Piping Design with Fiberglass FRP |
| Built-In Fluid Transient Analysis Can Easily Define and Solve Difficult Fluid Shock Loadings |
| The Benefits of Bentley's AutoPIPE Nonlinear Analysis Engine |
| Vessel Nozzles/Flange Design using AutoPIPE and AutoPIPE Vessel |
| Advanced Buried Pipeline Design Webinar w/ Bonus General B31 Code Major Changes for 2012 |
| Solving Real-World Industry Pipe stress Problems |
| Important Real World Piping Design Guidelines |
| How to Handle the Nozzle Loads |
Note: remove CONNECT Edition filter above to see all videos
| AutoPIPE V8i Special Interest Group |
| Adding a Standard Material to the MATL Library |
| Adding New Materials to an Existing .src File |
| AutoPIPE Common Help Topics |
| AutoPIPE Dynamic Results Interpretation and Two Point Flange Component |
| AutoPIPE Integration |
| AutoPIPE licensing |
| AutoPIPE New Features - v9.6.1 & v9.6.2 - AutoPIPE and AutoPIPE Vessel Integration |
| AutoPIPE New Features - v9.6.1 & v9.6.2 - New AutoPIPE Isometric Manager |
| AutoPIPE New Features - v9.6.1 & v9.6.2 - New Hydrotest Load Feature |
| AutoPIPE Vessel Real World Applications |
| AutoPIPE Wiki Page |
| Code Updates |
| Common Help Topics - AutoPIPE & AutoPIPE Vessel |
| Common Help Topics - AutoPIPE Vessel |
| Design Process for Pressure Vessels |
| Double Jacket Vessels |
| Drawing Creation |
| DXF Export for drawing generation |
| Elbow Fittings |
| Help Topics |
| Horizontal Vessel with Boot |
| Hot Clash Detection |
| Ignoring Friction in Occasional Static Analyses and Importing Combination Files |
| Importing into AutoPIPE |
| Insert > Xtra Data, Distributed Load and Report FIlters |
| Introduction |
| Introduction to Common Help Topics - AutoPIPE & AutoPIPE Vessel ISK |
| Introduction to Modeling Approaches |
| Managing Modeling and Analysis Features |
| Modeling Cold Springs and Different Types of Supports |
| Modeling Different Types of Supports |
| Modeling Pipe Racks of AutoPIPE |
| Modeling Special Components |
| Modeling Trunnion Supports |
| New Features in AutoPIPE v9.6.1 & v9.6.2 |
| Nonlinear Analysis for Hydrotest Condition, Export Nozzle Loads to AutoPIPE |
| PipeLink Integration between AutoPIPE and STAAD for AutoPIPE |
| Post-procesing |
| Project Specifications |
| Ring Main Wizard Tutorial |
| Stress Isometrics |
| StressISO drawing generation |
| Support Force Results |
| Tee Fittings |
| Tools > Settings and Insert > Xtra Data |
| Tools > Settings Menu |
| Types of Vessels Available |
| Victaulic Fittings and Different Types of Flanges and Valves |
| Working with Material in AutoPIPE |
| Working with Steel Supports |
| QuickStart for Engineers using AutoPIPE |
| Setting up AutoPIPE |
| Creating a New Model |
| Creating Piping Model Geometry |
| Completing the Creation of Piping Model Geometry |
| Reviewing a Piping Model |
| Running a Basic Static Analysis |
| Reviewing Analysis Results |
| Modeling Piping Geometry Skills Assessment |
| Modeling Piping Geometry Practice Workbook |
| Model Modification Practice Workbook |
| QuickStart for Engineers using AutoPIPE for CONNECT Edition |
| Setting Up Program Configurations |
| Creating Piping Model Geometry part 1 |
| Creating Piping Model Geometry part 2 |
| Modeling Piping Geometry PDF and Dataset Download |
| Inserting a Disconnected Segment |
| Editing Operations |
| Inserting a Pump part 1 |
| Inserting a Pump part 2 |
| Reviewing the Piping Model and Running a Basic Static Analysis |
| Managing Segments |
| Model Modification PDF and Dataset Download |
| Advanced Modelling and Analysis Using AutoPIPE |
| Non Metallic Piping Analysis in AutoPIPE V11 |
| Non Metallic Piping Analysis in AutoPIPE Practice Workbook |
| Non Metallic Piping Analysis in AutoPIPE Skills Assessment |
| Non Metallic Piping Analysis in AutoPIPE V11 PDF and Dataset Download |
| Non Metallic Piping Analysis in AutoPIPE V11 Skills Assessment |
| Spring Selection in AutoPIPE V11 |
| Spring Selection in AutoPIPE Practice Workbook |
| Spring Selection in AutoPIPE Skills Assessment |
| Spring Selection in AutoPIPE V11 PDF and Dataset Download |
| Jacketed Pipe Design in AutoPIPE PDF and Dataset Download |
| AutoPIPE Vessel |
| 01-Overview and Introduction |
| 02-Pressure Vessels |
| 03-Lifting Analysis and Fatigue |
| 04-Heat Exchangers Intro and Modeling |
| 05-Heat Exchangers Modifying the Bundle Layout |
| 06-Heat Exchangers - Additional Examples |
| 07-Heat Exchangers Importing Model Information |
| 08-Additional Vessel Types |
| 09-Post Processing |
| Dynamic Analysis Using AutoPIPE |
| Modal Analysis Using AutoPIPE and Dynamic Introduction V11 |
| Modal Analysis Using AutoPIPE and Dynamic Introduction Practice Workbook |
| Modal Analysis Using AutoPIPE and Dynamic Introduction Skills Assessment |
| Modal Analysis Using AutoPIPE and Dynamic Introduction V11 PDF and Dataset Download |
| Response Spectra Analysis Using AutoPIPE V11 |
| Response Spectra Analysis Using AutoPIPE Practice Workbook |
| Response Spectra Analysis Using AutoPIPE Skills Assessment |
| Response Spectra Analysis Using AutoPIPE V11 PDF and Dataset Download |
| Time History Analysis Using AutoPIPE - Water/Steam Hammer V11 |
| Time History Analysis Using AutoPIPE - Water/Steam Hammer Practice Workbook |
| Time History Analysis Using AutoPIPE Skills Assessment |
| Time History Analysis Using AutoPIPE - Water/Steam Hammer V11 PDF and Dataset Download |
| Time History Analysis Using AutoPIPE - Slug Flow V11 |
| Time History Analysis Using AutoPIPE - Slug Flow Practice Workbook |
| Time History Analysis Using AutoPIPE - Slug Flow V11 PDF and Dataset Download |
| Harmonic Analysis Using AutoPIPE V11 |
| Harmonic Analysis Using AutoPIPE Practice Workbook |
| Harmonic Analysis Using AutoPIPE V11 PDF and Dataset Download |
| Steam Relief Lift Analysis Using AutoPIPE V11 |
| Steam Relief Lift Analysis Using AutoPIPE Practice Workbook |
| Steam Relief Lift Analysis Using AutoPIPE V11 PDF and Dataset Download |
| Performing an ASME NB Analysis using AutoPIPE for CONNECT Edition |
| Performing an ASME NB Analysis Using AutoPIPE V11 |
| AutoPIPE CONNECT Edition Special Interest Group |
| Bentley CONNECT Edition Intro and Benefits and AutoPIPE Code Updates |
| AutoPIPE CONNECT Edition Feature Updates |
| AutoPIPE Vessel CONNECT Edition Feature Updates |
| Introduction and NLA Inconsistent Combos |
| Nonlinear Analysis Inconsistent Combinations |
| AutoPIPE Report Manager |
| AutoPIPE Ribbon GUI |
| Back to Basics Introduction |
| View Toolbar |
| Show Options and Active Point |
| Piping Fatigue Introduction |
| Piping Fatigue in AutoPIPE Nuclear |
| Piping Fatigue in AutoPIPE Non-Nuclear |
| Introduction to AutoPIPE Vessel How Tos |
| Toolbar Customization How Tos |
| Flange How Tos |
| Load Combination How Tos |
| Foundation Loads and Nozzle Projection How Tos |
| Introduction to AutoPIPE Vessel How Tos Part 2 |
| Importing AutoPIPE Nozzle Loads into APV |
| Using the PXF Nozzle Manager |
| Creating a Cell in the Microstation Library |
| Customizing Drawings Part 1 |
| Customizing Drawings Part 2 |
| 2016-10 AutoPIPE SIG - Static Analysis Options |
| 2017-02 AutoPIPE SIG - Working with the New Report Manager |
| 2017-04 AutoPIPE SIG - AutoPIPE "How Do I's?" |
| 2017-07 AutoPIPE SIG - Flange Analysis Module |
| 2017-11 AutoPIPE SIG - AutoPIPE Ring Feature |
| 2018-01 AutoPIPE SIG - AutoPIPE Setup Options |
| 2018-06 AutoPIPE SIG - AutoPIPE Interoperability with STAAD.Pro Using SQLite PipeLink Video |
| 2018-06 AutoPIPE SIG - AutoPIPE Interoperability with STAAD.Pro Using SQLite PipeLink Download |
| AutoPIPE Vessel for CONNECT Edition |
| Introduction to AutoPIPE Vessel |
| Introduction to AutoPIPE Vessel Download |
| Pressure Vessels |
| Pressure Vessels Download |
| Heat Exchangers |
| Heat Exchangers Download |
| Air Coolers |
| Air Coolers Download |
| Storage Tanks |
| Storage Tanks Download |
| Post Processing |
| Post Processing Download |
| LEARNing Conference 2015 - Structural Analysis and Design |
| Basic Static and Model Analysis |
| Importing the .pipelink file |
| Importing AutoPIPE Loads into STAAD.Pro |
| Using AutoPIPE Loads in a STAAD.Pro Analysis |
| Practice Workbook |
| Skills Assessment |
Tech Talk: Improving Stress Intensification and Flexibility Analysis with ASME B31J
Tech Talk: Minimizing Risk of Flange Failure with AutoPIPE Flange
AutoPIPE - Hot and Cold Clash Detection Benefits
AutoPIPE - Hot and Cold Clash Detection How-To
AutoPIPE - Stress Isometrics Using OPIM
AutoPIPE - Export SQLite DB to AutoPIPE Report Manager
AutoPIPE - OpenPlant to AutoPIPE to STAAD
AutoPIPE - ProStructures to STAAD to AutoPIPE
AutoPIPE - Hot Clash Detection
