Item #1: Is there an AutoPIPE Nozzle Tutorial or training available?
Answer:
As of Aug 2026, AutoPIPE Nozzle has been deprecated, however is being rolled into AutoPIPE as a module. We are planning on a solution to off user in 2027. Until then, please see the following:
Item #2: Example: Defining Nozzle Loads and Combinations in AutoPIPE Nozzle
Table Of Contents - AutoPIPE Nozzle Wiki page
