| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
| Date Logged & Current Version | March 2019 12.00.00.14 |
Does AutoPIPE round up the valve weight to closest whole value in the analysis or are the actual input values used in analysis and only the output reported values is rounded up?
The program uses the exact values entered into the valve dialog when performing the analysis. Due to space limitations, the report may have some input values that have been rounded to the nearest whole value.
