"Autopipe.exe" Messages displayed in AutoPIPE
The following messages appear in AutoPIPE:
  1. "The application failed to initialize properly (0xc0150002)"
    1. autopipe.exe - No Disk
      1. There is no disk in the drive. Please insert a disk into drive\Device\Harddisk2\DR2.
  2. "The application was unable to start correctly (0xc0000005)"
  3. The code execution cannot proceed because xxx was not found:
    1. CTL3D32.dll
    2. IEGlicLib.dll
  4. This application has failed to start because IEGLicLib.dll was not found
Warnings, Errors, Crashed, Confirm Messages
