| Version(s): | ALL | ||
| Area: | Installation | ||
When trying to start AutoPIPE the following error message appears:
“The application failed to initialize properly (0xc0150002). Click on OK to terminate the application”
This error can be caused by some installation issues of Bentley IEG License Service.
Or if STAAD Offshore was installed recently on the computer. STAAD offshore has its own version of Bentley IEG that is installed regardless if a newer version is already installed. This essentially downgrades the IEG service and corrupts other programs using it.
Steps:
1. Completely remove all “Bentley IEG License Service” versions from the computer (Control Panel-> Add/Remove Programs or Programs and Features). In addition delete all system folders for Bentley IEG
2. Reboot the computer
3. Download the most recent copy of Bentley IEG License Service from the Software Downloads link in CONNECTION Center
4. Install Bentley IEG License Service
5. Try to run all applications that use Bentley IEG (i.e. AutoPIPE, STAAD, STAAD Offshore, etc..)
