| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT; | ||
| Area: | Stress Isometric | ||
| Date Logged & Current Version | Feb. 2016 10.00.00.10 |
How to change the dimension font on an AutoPIPE Stress Isometric using OPIM?
This feature was related to border file. In order to change dimension font you have to perform following steps
1. In AutoPIPE launch Openplant Isometric Manager from menu “File > Launch Openplant Isometric Manager”
2. Open any border file you want to modify from “[Installation Directory]\isoextractor\Borders\...” i.e. I have selected DGN\A0BORD.DGN
3. From menu select Element>Dimension Styles. See snapshot below
4. On Dimension Styles dialog activate predefined style name “DimStyle”
5. Select Text tab
6. Change text style and font
7. Save the change on pressing the save button on Dimension Styles dialog
8. Close OpenPlant Isometric Manager.
9. Make sure to use the same border during export to Stress Isometric using AutoPIPE.
Customize AutoPIPE Stress Isometric drawings
