| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Results |
| Date Logged & Current Version | Feb. 2019 12.00.00.14 |
How Autopipe calculate the Forces and Moments to evaluate the "DNV local buckling category"?
Force and Moment components for Functional, Environmental, Interference and accidental categories are considered as per selections made on DNV Result Options dialog:
Forces and Moments components defined for corresponding categories are then used to calculate design load effects as per DNV code’s equation 4.6/4.8:
These components are then used by AutoPIPE to calculate “internal overpressure” (code’s equation 5.19) and “external overpressure” (code’s equation 5.28), as per applicable conditions for DNV local buckling category.
