| Product(s): | AutoPIPE Nozzle | ||
| Version(s): | V8i | ||
| Area: | Release Notes | ||
| Date Logged & Current Version |
Jan. 2015 08.11.08.24 |
Bentley® AutoPIPE Nozzle is a stand-alone, engineering application used for calculating local stresses at nozzle/vessel junctions, trunnion attachment points, clip connections and lug attachments on the vessel shell. Based on well-known engineering design standards like WRC, KHK, API and PD, AutoPIPE Nozzle helps engineers and designers quickly determine whether or not the wall of a pressure vessel, exchanger or tank can withstand piping loads on the nozzle or at clip and lug connections.
The following outline identifies new features and enhancements in the AutoPIPE Nozzle V8i 08.11.08.24
• AutoPIPE Nozzle ASME Code 2007 and database updates
• Update KHK code to 2006
• Update KHK material library to 2003
• Update JIS material library in JIS B 8265
• Average membrane and M+B allowables forDiv 2 allowable
• Filter material list according to selected design code
• Provide a check box to include or exclude the 1.2 increase factor for occasional loads
• Provide a check box to use averaged or non-averaged values for calculation of stress allowables e.g. evaluating cyclic loads for fatigue.
• Include different nozzle attachment types
• Allow importing loads from AutoPIPE v9.1
• Change apnozzle.map file format to CSV to support long filenames
• Consolidate AutoPIPE Nozzle design code licenses into one license
The standard configuration of program includes these features:
| ASME Div 1: |
< 2001 |
| >= 2001 3S | |
| >= 2001 2Fy (No Creep) | |
| ASME Div 2: |
< 2001 (No Creep) |
| 2001 < 2007 (No Creep) | |
| >= 2007 (No Creep). |
| Processor | Intel Pentium IV or higher |
| Operating Systems |
Microsoft Windows XP Professional SP3 or later OR |
| Web Browser | Microsoft Internet Explorer 6 or greater |
| Memory | 256MB |
| Hard Disk | 36 MB minimum free hard disk space |
| Graphics Card | Any industry-standard video card |
| Other Prerequisites |
IEG Security (free download at Bentley SELECT) |
| PDF Reader | Adobe® Acrobat Reader 8.0 or greater |
Before you install any software, you should confirm that you have adequate hardware and software capabilities to install and use the product.
AutoPIPE Nozzle is now bundled into AutoPIPE download, installation, and Licensing. There is no separate download and installation instructions. Please see AutoPIPE installation here for details.
AutoPIPE Nozzle software must be installed on a local client workstation.
AutoPIPE Nozzle data files (*.NOZ) must have full read/write access and can only be accessed from a local client workstation.
Program Help: Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions.
Documentation for AutoPIPE Nozzle applications is provided online in the CHM format. These files are accessible from the Help Menu and can be browsed, searched, or printed.
AutoPIPE Nozzle Quick Start guide is a PDF which can be browsed, searched, or printed with the Adobe Acrobat Reader.
Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
TRADEMARK NOTICE
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
COPYRIGHT NOTICE
© 2015, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the "AutoPIPE Nozzle" folder of the product installation.
685 Stockton Drive
Exton, PA 19341-0678 USA
Phone: (1) 610 458-5000
FAX: (1) 610 458-1060
WWW: http://www.bentley.com/
Bentley Systems Europe B.V.
Wegalaan 2
2132 JC Hoofddorp
THE NETHERLANDS
Phone: (31) 23 556 0560
FAX: (31) 23 556 0565
WWW: http://www.bentley.com/nl-NL/
Bentley Engineering Software Systems
Unit 1402-06, Tower 1
China Central Place, Beijing 100022
CHINA
Phone: (86) 10 5929 7000
FAX: (86) 10 5929 7001
WWW: http://www.bentley.com/zh-CN/
Bentley AutoPIPE Nozzle Release Notes
