| Version(s): | V8i |
| Environment: | N/A |
| Area: | Licensing |
| Date Logged & Current Version | August 2016 40.02.00.08 |
There are two methods for License activation: automatically with the Product Activation Wizard, or manually using License Management Tool.This procedure will only address Licencing using AutoPIPE Vessel's Installation Wizard
The following screen is automatically displayed after pressing the "Close " button on the screen above:
1. Choose the correct radio button from available listing (ex activae against Hosted server) and press Next
2. Enter the correct Site Activation Key and press the Test Connection button, the Sever and Activation key should be verified, before continuing.
NOTE: If you do not see "Activation Key Verified" dialog as shown above, contact Bentley Licensing department for assistance.
3. After the Single Sign-In dialog appears, select the correct radio button and press the "Next"button:
4. With Sing in now radio button selected, the next screen enter your Bentley sign in credentials, (hint: same as used for Bentley Communities), press Sign-In button
5. Select a country and Press the Next button
6. Verify the settings are correct and press the Finish Button:
7. If all they settings were correct the following is displayed:
The following maybe displayed:
8. Finish, AutoPIPE Vessel and Licensing are now installed !!!
AutoPIPE Vessel Read Me file should be displayed, suggest to review the "What is New" & "Changed" sections as they contain a list of enhancements and defects fixed.
How to License AutoPIPE Vessel?
