| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | library |
| Date Logged & Current Version | April. 2018 11.03.00.08 |
What to do when value entered exceeds program's maximum number?
Example, enter 9,000,000mm or 9 km
Easy, modify the Unit Library file coordinates units from mm to meters.
Remember, being a custom module, Bentley cannot be held responsible for the inaccuracy of the new library
content. It is your responsibility to verify the program's output reports in order to confirm functionality of the newly customize library.
