| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT | ||
| Area: | Install | ||
| Date Logged & Current Version | Dec 2017 11.02.00.08 |
How do I Install Bentley AutoPIPE CONNECT v.11.02.00.08 or v.11.04.00.10?
Following procedure can be used If AutoPIPE 11.01.00.23 or higher has already been installed. Otherwise see Manual installation below:
Install any additional updates or dependencies (i.e OpenPLANT Isometric Manager, ProjectWise, etc..).
Detailed installation procedures for these other applications can be found on other WIKI pages or in readme files.
Click here to see additional information below
Navigate to the EXE file download using the download procedure.
Double click on the "ap11020008en.exe" to start the installation process.
Note: Be patient while the application is installing as it is checking to verify programs already installed, verifying drive space, etc.. there may be periods when it appears nothing is happening. Give the system time. In the event the installation stops a warning / error will be presented. Just follow the prompts and be patient. Highly recommended that all applications are closed during the installation process. On average it will take 12 - 15 min to install everything.
See Movie below:
Note: If the following screen below appears, the user must restart the computer before the installation can be completed, click "Restart Now Button". Otherwise press "Restart Later" button to close the installation process, close all applications that are running, and then manually restart the computer to complete AutoPIPE installation.
After restarting, the application will automatically continue installing.
After clicking Finish button, AutoPIPE readme file will be displayed, click here for details of this file.
You are Finished !!!
AutoPIPE has now been installed:
If the program will not install based on the instructions above, please log a Bentley Service Request mentioning this page and include a copy of the Error log mentioned above
Install any Dependencies that were also downloaded (typically double click on the EXE files that were downloaded, i.e OpenPLANT Isometric Manager, ProjectWise, etc..).
Detailed installation procedures for these other applications can be found on other WIKI pages or readme files.
Before starting AutoPIPE, continue to STEP #3: Set-Up Licensing
Download, Install, and License AutoPIPE CONNECT 11.00.xx.xx and higher
