| Product(s): | AutoPIPE | ||
| Version(s): | CONNECT; | ||
| Area: | Stress Isometric | ||
| Date Logged & Current Version | Feb. 2016 10.00.00.10 |
How to modify data table number of rows per sheet on an AutoPIPE Stress Isometric using OPIM?
You can change number of data table rows per sheet from “stressiso.ini” file.
1. This file located at “[InstallationDirectory]\ stressiso.ini”.
2. Open file in any text editor and find “[DrawingFrame]” section
3. Here you see number of line defined for each border.
4. You can change the number of line from there
Customize AutoPIPE Stress Isometric drawings
