| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Calculation | ||
| Date Logged & Current Version | May. 2016 10.01.00.09 |
How does the program calculate ASME B31.1 allowable values in AutoPIPE?
Open AutoPIPE, see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> ASME B31.1> select a code year, see the various topics,
Read the entire entry. Somewhere in the write-up will be information about how AutoPIPE calculates the various allowable values for the output report.
Note: there are some settings under Tools> Model Options> Results that may affect the Allowable value, confirm these values and take them into consideration when calculating the allowable(s).
Equation/Nomenclature |
Location in AutoPIPE |
σ = W∙SE; SE = Ej∙SH | Code Calculation |
W = Weld Joint Strength W factor |
Insert/Modify > Pipe Properties |
Ej = Weld Efficiency Factor |
Tools > Model Options > Results |
SH = Hot Allowable Stress |
Insert/Modify > Operating Temperature and Pressure |
Equation / Nomenclature |
σ = k∙SH | Code Calculation |
k = k-factor |
Tools > Combinations > “Code Comb.” tab |
SH = Hot allowable stress |
σ = SH | Code Calculation |
SH = Hot allowable stress | Insert/Modify > Operating Temperature and Pressure |
if SA > SE σ = Sa If SE> SA and SH> SL σ = SA + f (SH - SL) | Code Calculation |
f = Range reduction factor |
SA = expansion allowable stress. |
Tools> Model Options> Results> Sustain Margin (Y/N/E) |
if Sustain Margin = Y > SA = f(1.25SC+0.25SH)+f(SH-SL) | |
if Sustain Margin = N > SA =f(SC+0.25SH) | |
if Sustain Margin = E> SA= f (SC+0.25SH) unless σ > SA, otherwise SA=f(1.25SC+0.25SH)+f(SH-SL) | |
f = Range Reduction Factor |
SC = Cold Allowable Stress |
SL = Sustained Load |
Taken from Sustained Load calculation |
ASME B31.1 Piping Code Calculation Issues
