SPIDAcalc v7 New Account Setup
The SPIDA software installers (.exe or .dmg) are available for download in the SPIDA Account Portal. Downloading software may require assistance from the Account Administrator or a company's IT Department. Therefore, installers can be downloaded by each individual user or by the Account Administrator or IT Department and then distributed to each user's computer individually.
Below are the instructions that will need to be followed to complete the Getting Started process.
Access the SPIDA Account Portal
Download
Note: Only the most recent installer per operating system is shown. To view and download older installers, click the Edit icon next to the correct operating system.
Installation
SPIDA software uses a familiar wizard process to walk through the installation. Installation may require an Administrator password and IT assistance.
For PC Users:
For Mac Users:
Activation
Activation of SPIDAcalc requires an API token. A unique API token can be generated under each user's login in the SPIDA Account Portal.
