| Product(s): | PULS | ||
| Version(s): | V8i | ||
| Area: | Installation | ||
| Date Logged & Current Version |
Sept 2007 08.09.00.29 |
Bentley PULS XM Edition is a stand-alone, Microsoft Windows engineering application used for the calculation of pressure pulsation, acoustic shaking forces and acoustic frequencies in piping systems. It can also be used for reciprocating compressor vessel sizing as per API 618 guidelines. PULS is an object-based graphical interface that provides fast model creation through the use of cut, copy and paste features that reduce repetitive input by the user. Pulsations and shaking forces can be instantly viewed by simply clicking directly on the model, eliminating the need to review voluminous batch output reports, typical of older methodology.
The following outline identifies new features and enhancements in the PULS V8i 08.09.00.28
| Processor | Intel Pentium-based PC 486 or higher |
| Operating Systems |
Microsoft Windows Vista OR |
| Web Browser | Microsoft Internet Explorer 5 or greater |
| Memory | 128MB |
| Hard Disk | 52 MB minimum free hard disk space |
| Graphics Card | Any industry-standard video card |
| Output Device | Any industry-standard output device supported by Windows |
| PDF Reader | Adobe® Acrobat Reader 8.0 or greater |
Before you install any software, you should confirm that you have adequate hardware and software capabilities to install and use the product.
Log a Bentley Service request asking for this update or download files from WIKI here.
PULS software must be installed on a local client workstation.
PULS data files (*.FDA) must have full read/write access and can only be accessed from a local client workstation.
TRADEMARK NOTICE
Bentley, the "B" logo, PULS, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
COPYRIGHT NOTICE
© 2015, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the "PULS" folder of the product installation.
685 Stockton Drive
Exton, PA 19341-0678 USA
Phone: (1) 610 458-5000
FAX: (1) 610 458-1060
WWW: http://www.bentley.com/
Bentley Systems Europe B.V.
Wegalaan 2
2132 JC Hoofddorp
THE NETHERLANDS
Phone: (31) 23 556 0560
FAX: (31) 23 556 0565
WWW: http://www.bentley.com/nl-NL/
Bentley Engineering Software Systems
Unit 1402-06, Tower 1
China Central Place, Beijing 100022
CHINA
Phone: (86) 10 5929 7000
FAX: (86) 10 5929 7001
WWW: http://www.bentley.com/zh-CN/
