| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Analysis |
| Date Logged & Current Version | June. 2017 11.00.00.22 |
Under what circumstances should ""Consider Bolt Spacing Correction" option be enabled on the Analysis Tab of AutoPIPE's flange Analysis module?
This is an engineering judgement call that you must decide. Read AutoPIPE help "ASME Section VIII, Bolt Spacing Correction Factor" for details about this feature.
Question: in reading help section there is a reference to "Leathel Service", that may not be perfectly clear. Does this refer to military vessels or to aeronautics?
Answer: AutoPIPE help information was created based on information from a particular codes. Refer to the indicated code for definitions and terminology. In this case there are Two definitions of lethal service provided in ASME VIII Div 1, section UW-2.
For legal reasons, Bentley does not provide code interpretations, the user must determine if a service is lethal. Suggest to submit a question to the code committee for interpretations about the code.
