| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Import | ||
| Date Logged & Current Version | Sept. 2015 09.06.02.06 |
When importing an ADL PIPE coverted ADI to NTL file into AutoPIPE The following is displayed:
Confirm
Import process successful. Review warning messages :
Yes No Cancel
Press OK button, AutoPIPE appears to be starting and the following occurs:
Bentley AutoPIPE Application Bentley AutoPIPE Application has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.[Close program]
Only option is to press "Close Program" button.
1. Check the ADL file to be sure all the information is correct
Example:
SE
NO ISO RCIC-659-1.2
PI 1 116.625 .562 27.8 6.23 180. 3.89
RU 1 3002 0.5
Note: pipe instruction format is missing the second node name.
Should be:
PI 1 3002 116.625 .562 27.8 6.23 180. 3.89
2. The piping code year specified n ADL PIPE is available in AutoPIPE version importing the file into.
