| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Import |
| Date Logged & Current Version | Sept. 2018 11.04.00.10 |
The following is found in the MSG log file:
*** ERROR: MATERIAL FILE NOT FOUND
Why, and how to avoid?
Be sure that the material file (xxx.LIB) specified on the PCF translator dialog screen is actually in the AutoPIPE directory folder. If not, select a material library that is in the folder.
Example:
On the PCF translator dialog screen, material library = B313-12,
What Material libraries are available in my version of AutoPIPE?
Answer: Start AutoPIPE, open the General model options and select the drop down menu for Material library files to see available material libraries, see below:
Note: AutoPIPE 9.5.x and lower does not have ASME B31.3 2012 piping code or material LIB file. Therefore, must change PCF material library to a LIB file available in the respective version of AutoPIPE.
Again, Only select those Material libraries on the PCF translator that are available in your version of AutoPIPE.
011-0011".
