| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Import | ||
| Date Logged & Current Version | June 2015 09.06.02.06 | ||
When importing an NTL file, the Fluid Density scale factor on the analysis set dialog is set to a default of 0.00. why?
A new enhancement was logged:
Defect 177463: Fluid density is not initialized to default of 1 when creating a new model using NTL Import.
Also when importing an NTL file using AutoPIPE V8i 9.4 - 9.6, the internal Fluid density value is set to 0.00. This cause a problem when performing a hanger analysis. This was logged under:
Defect 262594:Program does not initialize fluid density factor to 1.0 for hanger selection analysis set when importing NTL
Description:
When importing a model in AutoPIPE through NTL, the fluid density factor used by the program when performing hanger selection analysis is set to 0.0.
Avoidance:
The workaround is to save the model as 9.4.0 (File > Save As > AutoPIPE 9.4 Model (*.dat)) and then re-open in the latest version. This was the fluid density factor is reset to 1.0 for hanger selection set internally, and the results come out correctly.
Fixed version: AutoPIPE CONNECT 10.01 and higher.
