| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Message | ||
| Date Logged & Current Version | June 2015 09.06.02.06 |
When opening a model from a previous version (ex. 09.04.xx.xx) into a newer version of the application (ex. 09.05.xx.xx), the program performs a scan and notifies the user of potential issues by displaying a dialog box with some information. The user has the option to select one of the following: YES, No, or Cancel buttons.
Confirm
This model may be affected by a previous program defect
#10751 in which the reported stress results may be incorrect.
Would you like to review the evaluation report?
Yes No Cancel
Additional details about the issue are automatically displayed in the AutoPIPE Report Viewer
Example:
Defect #10751 Evaluation Report
@ Model Name: @Underground_Firewater_Piping_System
@ Model Version: @09.05.00.21
@ Program Version: @09.05.01.02
@ Report Filename: @Underground_Firewater_Piping_System_D10751.TXT
The reported stress values for soil points and kinks are revised in this version of program to correct Defect #10751.
Please refer to the published Defect Report for more details and instructions. To assist in the screening of this model for any potential impact by this defect, this program has examined the model's database and
has found that the stresses should be re-computed using this program version. After saving this model or running any analyses in this version or later commercial release versions, this screening will no longer be performed.
Note: select the following hyperlink to review procedure and limitations to accessing the published defect reports (aka AutoPIPE Error Reports).
AutoPIPE will not display the information and continue the process of searching for other known defects to be displayed and ultimately open the model in the program.
