| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Isometric | ||
| Date Logged & Current Version | July 2015 09.06.02.06 |
The following message appears when trying to create a stress isometric in AutoPIPE:
Confirm
No range has been selected. Do you want to export the complete model?
Yes No Cancel
Why and how to avoid it?
This message will appear if the Stress isometric "Use Selected Range" setting is enabled but nothing has been highlighted in the model before initiating the Save Stress Isometric command; shown below:
On the popup dialog, selecting:
Yes - if pressing "yes" the entire model is exported to a drawing file as if you had highlighted the entire model to be exported.
No / Cancel - if pressing "no" or "cancel" the command is canceled and the dialog disappears, AutoPIPE is now awaiting the next command.
In some cases, using multiple screens or docking station, this dialog may appear behind another window or may appear off screen. At this very point, try adjusting the screen resolution in hopes of re-sizing all the current dialog that are opened to all appear on screen per the new resolution setting. If this works, move the screen and reset the screen resolution back to the original value.
If this does not work, as a last resort, try uninstalling and reinstalling the application.
