21. Combinations Dialog Enhancements & Defects in AutoPIPE
Notes: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Defect 941070:
User load cases are incorrectly counted towards occasional load cases for inconsistent load combinations check
Defect 662949:
Non-linear combination consistency checker does not flag combinations with temperature case but no pressure case
Defect 568905 :
Update Hydrotest Code Combination Reporting for Non-Hydrotest Load Combinations
Enhancement 343288 :
Add Option to Import Code Combinations as Non-Code Combinations:
Enhancement 75414 :
Add feature to cal. common Max combinations per Load Set instead of Globally
AutoPIPE Enhancements Requests and Logged Defects
