| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | System Files |
| Date Logged & Current Version | April. 2017 11.00.00.22 |
Where to find CADAP.MAP file used by AutoPIPE?
The CADAP.MAP file is used by AutoPIPE when importing a PXF file. The file can be manually opened and modified with any text editor application (i.e. Ultra Edit, NotePadd ++, MS word, etc..). Once modifications are completed, save file to the same location.
location of the CADAP.MAP file varies depending on AutoPIPE version
Use one of 2 methods:
1. CADAP map file is located in the user settings directory. Explore it by typing %appdata% in the windows explorer address bar and navigating to AutoPIPE folder in Bentley directory.
C:\ Users\ [username] \ AppData\ Roaming\ Bentley\ AutoPIPE CONNECT\
2. Within AutoPIPE, open Tools> Settings> Preferences>
CADAP map file is located in the program folder.
C:\ Bentley\ AutoPIPE\
or
C:\ Program Files\ Bentley\ AutoPIPE\
