| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Command |
| Date Logged & Current Version | April. 2017 11.00.00.22 |
How to insert a USER SIF in AutoPIPE?
Command location varies depending on the version of AutoPIPE being used:
One location: Insert tab> Xtra Data group> Joint Type and User SIF icon button:
Also see binoculars in upper right corner to see more command locations:
Select drop down listing, Insert> Xtra Data> Joint Type and user SIF>
After initiating the command a new dialog will appear,
Note: dialog above may be different depending on Piping code and year used
1. Select the correct weld type
or
2. Choose "User Define" from the listing and enter the SIF values.
3. In addition, enable the check-box "Override all other SIFs at this point" (see online help to fully understand this setting) :
How Do I ..... in AutoPIPE: Table of contents
