| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Command |
| Date Logged & Current Version | April. 2017 11.00.00.22 |
How to review / create a model input listing in AutoPIPE?
Command location varies depending on the version of AutoPIPE being used:
Using the binoculars in upper right corner to see exact command locations, enter "Input Listing"
One location: Results tab> Reports group> Input Listing icon button
Select drop down listing, Tools> > Model Input Listing>
After initiating the command a dialog will appear, enable and disable selections as needed:
Note: press help button on dialog for details on each feature.
How Do I ..... in AutoPIPE: Table of contents
