Select the following image that applies:
| Application bar displayed "Bentley AutoPIPE Demo" | |
The means that a valid license for AutoPIPE Standard edition is not available in LMT. The Application is reverting to Demo Mode Select here to figure out what AutoPIPE Edition user is Authorized for. |
The means that a valid license for AutoPIPE Standard edition is not available in LMT. The Application will revert to Demo Mode Select here to figure out what AutoPIPE Edition user is Authorized for. |
The means that a valid license for AutoPIPE Advance (aka. PLUS) edition is not available in LMT. The Application is reverting to Demo Mode. Select here to figure out what AutoPIPE Edition user is Authorized for. |
The means that a valid license for AutoPIPE Advance (aka. PLUS) edition is not available in LMT. The Application will revert to Demo Mode. Select here to figure out what AutoPIPE Edition user is Authorized for. |
The means that a valid license for AutoPIPE Nuclear edition is not available in LMT. The Application is reverting to Demo Mode Select here to figure out what AutoPIPE Edition user is Authorized for. |
The means that a valid license for AutoPIPE Nuclear edition is not available in LMT. The Application will revert to Demo Mode Select here to figure out what AutoPIPE Edition user is Authorized for. |
Bentley AutoPIPE Standard - (Undefined)Program is now using an "AutoPIPE" License Start using the program or | |
Bentley AutoPIPE Advanced - (Undefined)Program is now using an "Advanced" License Start using the program or | |
Bentley AutoPIPE Nuclear - (Undefined)Program is now using an "Nuclear" License Start using the program or | |
Already in LMT:AutoPIPE - Trial expires in xx day(s) |
Interactive Guide to Licensing
