| Product(s): | AutoPIPE Nozzle |
| Version(s): | ALL; |
| Area: | Crashed |
| Date Logged & Current Version | April. 2018 11.03.00.08 |
The following appears when starting the application:
System Error
Input past end of file
OK
Why and how to avoid it?
Step 1. Start AutoPIPE Nozzle
Step 2. Open the following folder:
%temp%
or
C:\Users\username\AppData\Local\Temp
Step 3. Search for the following file with format = "daymonthyear".anl:
day = 04, month = 06, year =18
File name = 040618.anl
Step 4. This should be generated when starting AutoPIPE Nozzle. Confirm that this file exist,
If Yes, send a copy to Bentley Technical Support for review
If No,
a. Confirm read/write access to this temp folder location
b. Open LMT (License Management Tool)
i. On the License Checkout tab, confirm that AutoPIPE Advance and / or Nuclear are listed in the top section of the dialog (imaged below)
ii. On the Activation status tab, confirm that AutoPIPE Advance and / or Nuclear are set to Activated, If set to anything else, select that line and press "Activate" button in lower right corner of screen. After the light show, the status should have been updated to Activated, if not contact the Bentley License Department for assistance.
Completely uninstall AutoPIPE products, Including all Bentley AutoPIPE folders under
%appdata%
%programdata%
Warnings, Errors, Crashed, Confirm Messages
