Applies To | |||
Product: | AutoPIPE | ||
First Affected Version: | 11.01.00.00 | ||
Found in Version: | 11.01.00.17 | ||
Fixed and Released in Version: | 11.01.00.24 | ||
Area: | All | ||
Severity: | Critical | ||
Backlog Issue Number: | 737822 |
On duplicating a wind load, changing the wind direction of one case also updates the direction of duplicated case.
1. Open the wind load dialog (Loads -> Wind)
2. Press 'New' to create a new wind load case. The default direction in Global X.
3. Select the load case created in step 2 and press 'Duplicate'
4. Change the direction of section case to Global Y.
5. Press OK to save the load cases.
6. Load the wind load dialog again (Load -> Wind)
7. It can be observed that the wind direction of both cases has been changed to Global Y.
To illustrate this defect, see video:
Do not use the Duplicate key, instead when creating a new wind load case, press New button and enter data for each load case as needed.
The program must correctly duplicate the load case and changing the direction of wind in one load case must not affect the other case.
Critical and High issues released in v.11.01.00
Known Issues in AutoPIPE (Enhancements, defects, etc..)
