| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version |
Oct. 2017 11.01.00.23 |
How do I model large radius, back to back, bend piping using AutoPIPE?
Example:
See Video below to learn modeling technique that will help you model any back to back bend piping configuration.
Notes:
1. Select to increase the movie window above
2. Recall from earlier AutoPIPE trainings, node points are added to an existing segment by standing at a node point and insert Delta DX, Dy, DZ to the next point. Thus when modeling 2 back to back bends. The closest distance between 2 bend TIP (Transition Intersect Point) cannot be any closer than the radius of the first bend plus the radius of the second bend ( or double the radius if both bends are exactly the same size component). See AutoPIPE examples below, and AutoPIPE help> modeling Approaches> Modeling Approaches> Bends> 180° Elbow)
Again, with this technique one can model the following shapes by simply changing the bend radius and location of node points.
You will need to adjust this depending on your required geometry. At this point you can place supports along the pipe.
results:
