| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Note Message | ||
| Date Logged & Current Version | May. 2016 10.01.00.09 |
The following appears when importing / opening a model in AutoPIPE:
Note
N13-83: Pressure extension has been enabled in the analysis.
OK
why and how to avoid it?
First of all this is a note message, as such it is not an Error or something bad just a reminder to the user that "Pressure extension has been enabled in the analysis". Pressure Extension load case options is typically found under Load> Static Analysis Sets> for any analysis set, the column option
See AutoPIPE Help for details on this setting.
