| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version | Aug. 2018 11.04.00.10 |
When installing AutoPIPE the following is displayed:
Error
E102-161: This point does not have reference point defined.
OK
What does this mean?
How to avoid?
When inserting a Rotating Equipment component, Entering a node point for the Suction / Discharge point requires there to be a reference point to ensure proper side of the node point is considered during the calculations.
Close the Rotating Equipment dialog and insert Reference points at both the Pump Suction or Discharge node points.
Example:
Segment A - Suction
Segment C - Pump body
Segment D - Discharge
insert Reference point at node points A00 and D05.
