| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Export | ||
| Date Logged & Current Version | June 2015 09.06.02.06 |
How to transfer the files from, AutoPIPE-AutoPLANT ?
With AutoPIPE opened, see program Help for information on Exporting files to AutoPLANT. Please see the following AutoPIPE help section:
1. Help > Contents> Search Tab> enter "Exporting a model" (include the quotes), press List Topics button, double click on the selected topic from the list provided to see more information:
Select "AutoPLANT (PXF) - Geometry/Results"
OR
2. Help > Contents> Contents Tab> Command Reference> File Commands> Exporting a Model> AutoPLANT (PXF) - Geometry/Results
In AutoPIPE V8i 09.06.01.11 use File> Export> AutoPLANT (*.PXF) command.
Note:
1. Use Zoom > Extents command before export file to any file format.
2. Be sure to check review the "AutoPIPE to AutoPLANT Mapping Files" link at the bottom of this page for additional features
