The following Release Notes are provided as a reference by Bentley's Technical Support Group.
 Version Number:          33.03.00.20
 Date Posted:                 2/19/2015 2:58:00 PM
 Application Group:      SELECT Released Products
 Language:                     English
 Operating Systems:
Windows Vista
Windows Vista x64
Windows 7
Windows 7 x64
Description
Bentley AutoPIPE Vessel V8i is a stand-alone, Engineering application for the comprehensive calculation of pressure vessels, heat exchangers, tanks, and air coolers to ASME, European, French CODAP, German ADM,and Russian GOST standards. It is the only program to perform truly optimized vessel design in minutes and produce fully automated detailed drawings and cost estimates.
This is maintenance release 3 for AutoPIPE Vessel V8i which includes several bug fixes.
Design Codes
ASME VIII Code.
BS PD 5500 Code.
CODAP Div.1 & Div. 2 Code.
AD MERKBLATTER Code.
European Standard EN 13445 Code.
Russian GOST R 52857 Code.
Considering pressure, temperature, external loads, wind, earthquake and local loads.
Creating calculation report using English, French, German, Russian language...
Enhancements:
- Improved the export of 3D platforms, ladders, and stairs to Microstation 3D drawing
- Sizes of columns, girders, and rafters are added to the 2D drawing parts list for tanks
- Improved the view manager with a bigger window and new tools in the toolbar
- More detailed drawings with fabrication details can now be created
- Ability to view platforms, ladders, and stairs in the 2D drawings created for Microstation or AutoCAD
- Updated the support for AutoCAD 2015
- Updated the support for SolidWorks 2015
- Added the ability to draw Long Weld Necks built according to GOST R 52630-2012
- New RSS Newsfeed client specifically for AutoPIPE Vessel now available
- New North Direction Arrow added for software integration
- Windows within AutoPIPE Vessel will now automatically be stacked on top of each other for horizontal vessels and set side by side for vertical vessels
- Now have the ability to open Bentley Dashboard from AutoPIPE Vessel
- Added the ability for the design of body flanges with external loads
- Added Occassional Load according to IBC 2006, 2009, & 2012 code years
- Added the option for input of the "C" value for tubesheet design to AD Code
- Anchor bolts can now be designed with combined shear and tensile loading
- Now have the ability to disable UG-23 (d) for skirts for exceptional conditions
- Design error reporting on the screen is now easier to see in the software results section window
- Now have the ability to choose which reinforcement areas are included in the reinforcement calculations
- Updated the calculations for test pressure for GOST codes
- User can now switch the program's view to 2D sketcher only, 3d sketcher only and both.
- Language pack are now merged in order for users to switch between software languages
- Add the ability to compute vessels design under wave motions and blast conditions
- Users now have more flexibility to choose the formula used to compute stresses
- Added ASME Code Case 2695 which allows Division 2 Rules to be used on a Division 1 design
- Users can now export and i-Model 3D DGN of their vessel design which includes components like platforms, ladders, and stairs
- Added the ability to have old versions of AutoPIPE Vessel installed while also keeping most up to date version installed as well
- Users can now input their own nozzle pipe sizes including diameter and thickness
- Users can now import nozzle loads directly from AutoPIPE
- Expansion coefficients for GOST R 52857.1 have been updated to the 2007 code
- Saddle heights on stacked heat exchangers can now be input seperately
- Zoom and pan features in 2D sketcher view have been updated to work similarly to the 3D view
- Selecting the component from the navigation/component list will now highlight the selected component inside 3D view
- Roundtrip integration with AutoPLANT is now available
- Improved Help documentation with improved seach ability and includes How To's and links to Be Communities
- Load Case Definition Dialog has been completely updated for better design input
- Design error reporting in the Word report is easier to navigate and see with the addition of bookmarks and highlighted text
- Users can now modify the B factor for occasional loading
- Users can now add a safety factor to increase the weight of vessel components and liquids
Defects
- #134847: Calcul: Fireproofing and insulation might not be taken into account for some wind calculation
- #74155: Fatigue analysis: remove time scale unit, add the possibility to enter a total cycle number manually.
- #99887: The boot component default temperature is not the temperature of the component containing the boot.
- #101376: ASME Div.1: self-reinforcing nozzle with an angle of the reinforcement equal to 0°, A5 area is not calculated.
- #133390: Wrong external pressure curve for SA537CL2 (the choice of the curve depends on the thickness)
- #79520: MDMT for tubesheet (Integral with Shell or Channel) not calculated (CODAP, EN13445)
- #82325: Ambiant Yield stress for CODAP anchor is used for the Operating and Shutdown cases.
- #84800: Calculation of flanged part of tubesheet for DEU (in differential pressure, the flanged part was calculated with the shell side pressure).
- #87707: GOST R 52857.7 - tubesheet equivalent pressure (pp) uncorreclty calculated
- #87710: GOST - Flange cover incorrectly calculated (Ykp value).
- #88425: Weight of saddles of stacked exchangers (when saddles geometry are the same, weight are different).
- #95015: GOST flange and cover under external pressure (calculation crash).
- #103341: Calculation of weld seams and metal equiv. for brackets support
- #130242: MAWP Cone calculation according to CODAP 95
- #132896: wrong fillet thickness for pass partition plate (TEMA RCB 9.133)
- #115575: Incorrect allowable stress for bolts (as Per 2011 ASME Sec IID, SA193B8 Gr2 bolt allowable stress for 1-1/4 in or M27 is 112 MPa (20,000 psi) ).
- #87744: Fatigue Analysis cycles (time calculation for cycles definition)
- #136580: Selection of an anchor bolt diameter for vessel supported by brackets
- #146996: Wrong wind for vessel on brackets if wind and earthquake in ASCE (the wind load calculating is different of the wind load applied on the vessel ).
- #125486: External Pressure on a Cylindrical with a Skirt connected on the junction of a conical shell (the skirt thickness is taken into account to calculate the minimum thickness of the section)
- #148190: Crash in Fatigue Analysis (when a lot of vertex are inputted).
- #123241: BHU heat exchanger type: the drawing of the impingement plate/rods is not correct in the 3D render view
- #119515: Use of AutoPIPE Vessel on the second monitor (toggle 2 screens to 1 screen when the UI was in the second screen)
- #146996: Wrong wind loads for vessel on brackets when Wind and Earthquake are according to ASCE
- #155771: Anchorbase designed as a component: program crash if using GOST or CODAP code.
Readme File:
Click Here
The Readme file identifies new features and enhancements in the V8i SS1 of AutoPIPE Vessel v33.03.00.20.
Download, Install, and License AutoPIPE Vessel:
The following procedure is perfectly suited for installing the newer version, only change being the version of the software being downloaded should be 33.03.00.20:
How do I download, install, and license AutoPIPE Vessel 33.02.00.06 on Win 7
Product Data Sheet
Click Here
Product Technotes & FAQs
