| Product(s): | PULS | ||
| Version(s): | V8i | ||
| Area: | Installation | ||
| Date Logged & Current Version |
Sept 2007 08.09.00.28 |
Bentley PULS XM Edition is a stand-alone, Microsoft Windows engineering application used for the calculation of pressure pulsation, acoustic shaking forces and acoustic frequencies in piping systems. It can also be used for reciprocating compressor vessel sizing as per API 618 guidelines. PULS is an object-based graphical interface that provides fast model creation through the use of cut, copy and paste features that reduce repetitive input by the user. Pulsations and shaking forces can be instantly viewed by simply clicking directly on the model, eliminating the need to review voluminous batch output reports, typical of older methodology.
The following outline identifies new features and enhancements in the PULS V8i 08.09.00.28
All three PULS Options are installed from one executable. The license file received from Bentley BAC will initiate your specific application.
Limited to 5 nodes.
Limited to 400 nodes and 1 double acting (or two single acting) reciprocating compressor cylinders. Also supports triplex pumps. This version is recommended for analysis of liquid systems or flow induced pulsations.
Incorporates all of the features of the PULS Option1 version, as listed above with the following additions:
Limited to 400 nodes and 9 double acting reciprocating compressor cylinders. This version is the minimum requirement for most reciprocating compressor analysis.
Incorporates all of the features of the PULS Option1 and Option2 version, as listed above with the following additions:
Limited to 999 nodes and 99 double acting reciprocating compressor cylinders
| Processor | Intel Pentium-based PC 486 or higher |
| Operating Systems |
Microsoft Windows Vista OR |
| Web Browser | Microsoft Internet Explorer 5 or greater |
| Memory | 128MB |
| Hard Disk | 52 MB minimum free hard disk space |
| Graphics Card | Any industry-standard video card |
| Output Device | Any industry-standard output device supported by Windows |
| PDF Reader | Adobe® Acrobat Reader 8.0 or greater |
Before you install any software, you should confirm that you have adequate hardware and software capabilities to install and use the product.
To download the products, create a MySELECT CD or to complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles you will need to obtain the name of your Site Administrator from the Bentley website at SELECTservices Online at http://selectservices.bentley.com/. Select MySupport Account / Permissions. Clicking on the List SELECTservices Administration button will access the Site Administrator at your company enabling you to request that the appropriate permissions be added to your profile.
With the appropriate privileges you can obtain the software as an electronic file from Web Downloads or the products may be ordered on a personal CD through MySELECT CD. Once you have installed the desired product you will need to complete the product authorization process by obtaining a license file from Bentley.
SELECT Services Online / MySELECT CD: When you order a custom CD from MySELECT CD the product directory structure for this product appears as shown. To install from the CD locate and run the setup.exe file and follow the online instructions.
The installation program will guide you through the process, prompting you for information when required.
If you are upgrading from an earlier version of the application, it is highly recommended that you do not install this product over the previous version.
|_plantcaepuls
|_08090028en
|_install
|_setup.exe - This initiates the install process
Note that you will need to install Bentley IEG Security for PULS licenses to work. IEG security can be downloaded from SELECT services online and would appear as pre-requisite for PULS XM.
Downloading the files from SELECT Services Online/Download - the download process gives you a choice to save the file to a specified location, or to begin the installation from the download area.
PULS software must be installed on a local client workstation.
PULS data files (*.FDA) must have full read/write access and can only be accessed from a local client workstation.
PULS Standard, PULS Plus, and add-ons are are all supported on the SELECT Server V8i Licensing. If you are upgrading from an earlier version of the product, it is highly recommended that you do not install this product over the previous version. Older versions of PULS 6.0, and 6.1 will run under SELECT Server XM Licensing using the SELECT Server XM Gateway Service and the older SELECT licenses. For more information on the SELECT Server XM Gateway Service see the PULS Quickstart.pdf.
The PULS products can be authorized as Standalone Licenses (formerly called Fixed Licenses), fixed to one user workstation or as Concurrent Licenses (formerly known as Floating Licenses) running from a local or Bentley hosted SELECT Server V8i.
If you are upgrading an existing installation to run on one workstation, and you have License Tool privileges you can obtain a license file to complete the authorization process. Access the License Tool at http://selectservices.bentley.com/ from My Support Account menu located on the left. Once you complete your request you will receive an email including a License File with instructions for completing the process.
Concurrent Licenses (formerly known as Floating Licenses) are now managed through Bentley SELECT Server V8i, a benefit of Bentley SELECT. Using SELECT Server V8i requires a valid Bentley Serial Number, site server name and activation code to authorize the application. The Serial Number you received when you purchased the application is used to obtain a License File to complete the authorization process. For more licensing information see the PULS Quickstart.pdf.
Important: A signed SELECT agreement must be on file in order to convert your licenses from Floating Licensing to Concurrent Licensing.
Users who have existing Floating Licenses and wish to convert the licenses to run on SELECT Server V8i can contact BAC from the website at http://www.bentley.com/en-US/Services/Bentley+Administration+Centers.htm. The following information is required when requesting SELECT Server V8i licensing: Server Name, email address of the recipient of the SELECT Server V8i license and the Serial Numbers to be added to the server.
Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions.
Documentation for PULS is provided online in the Adobe.pdf format. These files are accessible from the Help Menu. All documents can be browsed, searched, or printed with the Adobe Acrobat Reader.
Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
If you do not have access to the World Wide Web, please contact us so we can provide you with the necessary files for using the Adobe Acrobat Reader.
TRADEMARK NOTICE
Bentley, the "B" logo, PULS, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
COPYRIGHT NOTICE
© 2015, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the "PULS" folder of the product installation.
685 Stockton Drive
Exton, PA 19341-0678 USA
Phone: (1) 610 458-5000
FAX: (1) 610 458-1060
WWW: http://www.bentley.com/
Bentley Systems Europe B.V.
Wegalaan 2
2132 JC Hoofddorp
THE NETHERLANDS
Phone: (31) 23 556 0560
FAX: (31) 23 556 0565
WWW: http://www.bentley.com/nl-NL/
Bentley Engineering Software Systems
Unit 1402-06, Tower 1
China Central Place, Beijing 100022
CHINA
Phone: (86) 10 5929 7000
FAX: (86) 10 5929 7001
WWW: http://www.bentley.com/zh-CN/
