| Product(s): | AutoPIPE Vessel | ||
| Version(s): | Connect | ||
| Area: | Release Notes | ||
| Date Logged & Current Version | Sept 2016 40.01.00.09 |
Product Name: |
Bentley AutoPIPE Vessel CONNECT Edition |
Version Number: |
40.01.00.09 |
Application Group: |
SELECT Released Products |
Date Posted: |
9/9/2016 2:23:06 AM |
Language: |
Russian |
Solution: |
Pipe Stress Analysis |
Operating Systems: |
Dependencies: |
Bentley AutoPIPE Vessel CONNECT Edition is a stand-alone, engineering application for the comprehensive calculation of pressure vessels, heat exchangers, tanks, and air coolers to ASME, European, British PD, French CODAP, German ADM, and Russian GOST standards. It is the only program to perform truly optimized vessel design in minutes and produce fully automated detailed drawings and cost estimates.
Major New CONNECT Edition Update 1 features include:
NOTE: Problems described below represent specific issues with specific test cases. It is difficult to succinctly describe a problem and how it impacted the specific test case. If you have any questions about the issues discussed in this report, please contact your technical support.
Note: For additional information on release notes and system requirements see the Readme document here
Readme Release Notes for AutoPIPE Vessel
