12. Soil Load Enhancements & Defects for AutoPIPE
Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Defect 771591:
Defect 771591:Delete Soil ID doesn't work
Defect 377936:
Program doesn’t ask to save changes made to "Buried Pipe Result Options"
Defect 377936:
Program doesn't save "Buried pipe result options" data for imported models
Defect 161317:
Soil properties applied to selected points is updated to the last Soil ID that is modified using "Modify > Properties of Soil Identifier"
Enhancement 128996:
Provide option to increase number of decimal precision on support calculator dialog
Enhancement 113001 or CAE-CR-5848:
Add option for above ground continuous support with friction
Enhancement 77117:
Soil Overburden Loads and Seismic Wave Data
Enhancements Requests and Logged Defects
