| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Modeling |
| Date Logged & Current Version | Nov. 2016 10.01.00.09 |
How does AutoPIPE calculate the weight of a typical pipe fittings (i.e. Tee, elbow, reducer, etc..)?
AutoPIPE fittings are made up of equivalent center-line length of straight pipe with assigned pipe properties. Changes to the pipe properties used to construct a fitting will account for different fitting weights.
Reducer are the only exception, (from AutoPIPE help):
Over the length of the reducer, AutoPIPE assumes an average of the connecting pipes for the outside diameter (Do), wall thickness (t). This affects the reducer weight, pipe contents weight, and section properties. Material properties (E, a, and allowable stresses) from the pipe at the near end of the reducer are extended to the far end of the reducer.
Reducer Piping Components - Modeling Approach
