03. Comments, Questions, and Answers about AutoPIPE's Hoop code combination
Item #1: Why is the ‘Max P’ load-case a default AutoPIPE Code combination?
Item #2: AutoPIPE results does not seem to consider the pipe properties wall thickness with regards to Corrosion Allow. or Mill tolerance, only the Hoop Stress changed, why?
Item #3: Why are the HOOP stress results different throughout the AutoPIPE model?
Item #4: When comparing the hand calculated hoop stress results with that calculated by AutoPIPE they are different, why?
Item #5: Why are hoop stresses 0.00 / None?
Item #6: Set HOOP Stress allowable for both Operating or Design Pressure
"Code Compliance" sub-report using Results> Output Report
