| Version(s): | 2004, XM, & V8i | ||
| Area: | licensing | ||
How to Request an updated license for a Deployed Select Server
Note: this procedure can only be completed by a Bentley On-Site Admin, if you do not know who that is please select this link here.
From the Select Server XM Administrative Interface:
Go to “License Management” -> “Request/Update License”.
Make sure the "Serial Number:" and "Activatation Key:" are correct. Check off "Force Full Retrieval" (make sure there is a check mark in the box) and click "OK".
Server Serial #: abc123
Server Activation Key: abc123
After the request is done processing, verify that the license that was imported is correct, and then click "Accept" ("Accept" only present on pre-v9 SELECTServer only).
License Management Tool (LMT) issues
