| Version(s): | ALL | ||
| Area: | Analysis | ||
Is it possible to perform a time history analysis on imposed support displacement movements in AutoPIPE?
Impose support displacement can only be applied with to the following load cases:
| Load-Case | Definition |
| GR | Gravity |
| T1 - T100 | Thermal (Operating) cases 1 to 100 |
| E1 - E30 | Earthquake case 1 to 30 |
| W1 - W10 | Wind cases 1 to 10 |
| P1 - P100 | Pressure cases 1 to 100 |
| U1 - U140 | User defined cases 1 to 140 |
| S1 - S10 | Seismic Anchor Movement cases 1 to 10 |
Therefore, Impose support displacement cannot be combined with Time History analysis at this time.
