| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version | April. 2018 11.03.00.08 |
How are the seismic displacements of structures entered in an AutoPIPE model?
Suggest to use the integration between AutoPIPE and STAAD. With these programs, these displacements are entered in as imposed displacements and would then be assigned to a SAM (Seismic Anchor Movement) load case like S1 case, SAM would be considered as a form of an earthquake load case.
