| Product(s): | AutoPIPE | ||
| Version(s): | V8i | ||
| Area: | Calculations | ||
| Date Logged & Current Version | Aug. 2015 09.06.02.06 |
For ASME B31.4, why are the fields "Use nominal thickness" and "Use nom. Thk. for Hoop" unchecked in AutoPIPE V8i 09.06.00.15?
This is correct and our implementation is inconsistent with our online help as well. A new enhancement (TFS-E75309) has been logged to update the online help.
