To download Certificates-
- Navigate to https://education.bentley.com/
- Sign in with your credentials.
- Go to My Certificates section appears on the left pane and click on Learn More it will take you to the My Dashboard page.
- OR you can click on the small triangle that appears next to your name on the extreme right hand upper corner of your Computer screen and select My Dashboard.
- Now scroll down till you find the Transcript & Certificates section.
- Open the certificate by clicking this
icon, which will open another window where you can save or print the PDF (Certificate).
To check the Badges-
- Go to My Badges section appears on the left pane and click on Learn More it will take you to the My Dashboard page.
- Now scroll down till you find the Badges section.
- You will find all your earned badges displayed in this section.
