BS7159 Piping Code Calculation Issues in AutoPIPE
Note: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> select a piping code to see the calculations performed by AutoPIPE.
Comments, Questions, and Answers about BS 7159 piping code calculations in AutoPIPE
Item #1: How are the default material (AutoGRPM.SRC) values calculated?
Item #2: Why does BS 7159 thermal expansion seem to be discounted in the stress results?
Piping Code Calculations
