AutoPIPE 6.xx:Download, install, license
How to download, install, and license AutoPIPE 6.0, 6.1, 6.2, 6.3?
TR Number: None
Product: AutoPIPE
Version: 06.xx.xx
Area: General, installation
Problem ID#:  76344
 Perform the following procedure:
Note: If installing older version of application on a new OS, please refer to following WIKI page for additional information.
AutoPIPE 6.x cannot be downloaded from the Bentley Web site, please submit a service ticket requesting the application.
a. Install AutoPIPE using all the default settings.
 Note: application should install to C:\ drive (Do not start the application at this time.)
b. Because each version of AutoPIPE installs a pre-bundled "Plant Security manager" application version, delete/uninstall the following applications from the computer:
i. Plant security manager
ii. Rebis Security
Also remove their respective folders on the "c:\" drive.
c. Download and install Plant security - see AutoPIPE 6.1 or 6.2 license.zip
d. Download and install Bentley IEG - see AutoPIPE 6.1 or 6.2 license.zip
e. Reboot the computer
1. License AutoPIPE 6.1 or 6.2 : Click Here
2. License AutoPIPE 6.3 the same as AutoPIPE 2004: Click Here.
How do I download, install, and license AutoPIPE?
