| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Graphic |
| Date Logged & Current Version | Nov. 2016 10.01.00.09 |
Why is anchor graphic partially rotated in AutoPIPE?
This issue is caused by precision of beam coordinates. Initially X coordinate of Node I is -3.7199 and when the beam dialog is opened and OK is pressed then the X coordinate change to -3.72.
