| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Stress Isometric | ||
| Date Logged & Current Version | Jan. 2016 10.00.00.10 |
After creating a Stress Isometric drawing, the results is that there is a lot of white space around the drawing. How to customize the drawing to reduce the amount of white space on each stress isometric?
Open the following file in any text editor (Ultra edit, NotePad++, Ms Word, etc.)
“[InstallationDirectory]\isoextractor\projects\project01\stress\Config\style.cfg”.
Scroll down and perform the following:
Note: this may be an iterative process.
Customize AutoPIPE Stress Isometric drawings
